2N Engine Top Speed Setting
Tom in MS
I had posted about this previously. This is a 2N that I'm asking about for my brother. I do not have a way to check the RPMs, but I know top RPMs as they are now are about half the top RPMs of my 2N. I know how and have adjusted these carburetors many times before, but I guess I have just forgotten. Can somebody just give me a simple abbreviated way to set this top engine speed?
Thank you.
The simplest way to adjust top speed is to do as advised in the FO-4 service manual. I an't going to type it all out. How do you know yours is not over reving? 2200 is max.
How do you know it's a carburetor adjustment? It may be a governor adjustment or defect. Try disconnecting the rod from the throttle plate to the governor and rev up the tractor by hand. What happens?
Thanks to all of you who responded and pointing me in the right direction. My son came by and he found what we need in the FO4 and also found a good video done by women.
