I looked up the process for tuning up the 2N Front Mount Distributor on this site and the manual. I pulled the distributor and replaced the points, condensor and cap.
I double checked the points and put everything back together and it would not start.
I disassembled everything and adjusted the points again, but it would not start.
The manual said to adjust on the low, so that is where the .015 is measured? It will then open up wider from there and never touch each other?
Any idea on what I should be checking to get ole Susie back up and running?
