2N fuel problem
ronboy
1st of all, thanks for help in the past on this forum. My 2N will not not run over 5-10 seconds ( 30-60 seconds if let sit a day or two). One guy from dealership told me probably need carb float adjustment, but I wonder about that. The bowl is clean and fuel flows freely into it and into carb. Any ideas? Thanks in advance to any who can give me something to look for.
(quoted from post at 23:53:25 09/18/11) 1st of all, thanks for help in the past on this forum. My 2N will not not run over 5-10 seconds ( 30-60 seconds if let sit a day or two). One guy from dealership told me probably need carb float adjustment, but I wonder about that. The bowl is clean and fuel flows freely into it and into carb. Any ideas? Thanks in advance to any who can give me something to look for.
You say fuel flows freely into the carb, what about out of the carb thru the bowl drain in botton. It should fill a pint jar in 2 to 3 minutes. just having fuel here means nothing. you have to have the required amount.
Good luck
Sounds more like a spark problem. Could be a bad condenser or a bad ballast resister or a bad ignition switch. I would hot wire it right from the battery to the coil. DO NOT leave it hooked up that way long or you will fry the coil. If it runs then you know your problem is from the coil to the battery. If it does not run say 15 minutes. If the same problem is still there could be a bad condenser. Most of the time a fuel problem will let one run for 10 minutes or so
It is important for you to tell us if your tractor has a 6 volt or 12 volt electrical system. The troubleshooting is different based upon the configuration of your engine.
It takes three things for an engine to run: spark at the right time, compression, & fuel in the right mixture. For the moment, forget about compression & concentrate on narrowing the problem down to spark or fuel.
In other words, it could be spark (condenser, points, etc) or fuel. (the float). You need to do some troubleshooting to narrow it down to one or the other.
There are three very important tools you always need to have in your N tool box: a 3 inch piece of wire w/ alligator clips on each end, an old spark plug w/ the gap opened to at least 3/16” ( ¼” is better) and a 7/16 box end wrench. (see tip # 50 at the link below) And, you really do need a working ammeter on the tractor; it is a very important diagnostic tool. With these tools, you can quickly narrow down most N problems to spark or fuel.
Next time it stops, check quickly for fuel then spark. When I say quickly, I mean get off the seat, grab the tools & do it right then. Do not wait a minute or two. First, check for fuel. Get a can & put it under the carb. Remove the bolt in the bottom of the carb; as long as the fuel is turned on, you should see gas flowing out of the carb. Let it run for at least 30 seconds. If it’s a dribble, or runs for 5 seconds & stops, or none at all, you have solved half the problem: it’s fuel related. If gas flows well out of the carb & only stops when you turn it off at the sediment bowl, chances are very good it’s not a fuel problem. So, next, turn the key on, crank the engine & look at the ammeter. What is the needle doing? Does it show a constant discharge, no movement at all, or does it move back & forth slightly? Next, get the old plug, ground it to a rust & paint free spot on the engine, turn the key on & crank the engine. If the spark jumps the 3/16” gap, you probably don’t have a spark problem. If it won’t jump the 3/16” gap, you have a spark problem. If the ammeter needle shows a constant discharge, or doesn’t move at all, that also tells you that you have a spark problem. Jump the ignition switch w/ your jumper wire & see what happens. If it runs, you found the problem. If it doesn’t have spark after you jump the ignition switch, post back for more info on further troubleshooting. (and do not forget to turn the ignition switch off; see tip # 38)
If it does not have gas coming out of the carb at a steady stream w/ the bolt out for at least 30 seconds, you have a fuel problem. First, remove the gas cap. Your vent could be clogged & it vacuum locked. If that doesn’t work, tap the carb bowl w/ a hammer handle in case the float is sticking closed. (don’t whack it w/ the head of the hammer; you can crack the bowl). If you still don’t see gas flowing, the N has three fuel screens; one in the brass elbow, one in the top of the sediment bowl & one on the stem of the sediment bowl in the gas tank. Check the screen in the elbow & the screen in the top of the sediment bowl. (don’t worry about the one in the tank) Both probably need to be cleaned. If you have the fuel knob turned on all the way, & 1 gallon or less in the tank, it may be trying to feed off of the reserve inlet which is probably clogged. Only open it 2 full turns. Put at least 2 gallons in the tank. (and do not forget to turn the gas off; see tip # 9)
There are ways to check for spark & fuel that work & ways that don't. For example, having gas to the carb is nice, but having it past the float is what counts! That’s why removing the bolt in the bottom of the carb is the way to do it. And, same thing w/ spark at the plugs. Some folks think that checking for spark means pulling a plug wire off & looking for one. Well, it's the distance the spark jumps at the plug that gives you the info you want. It takes about 17kv to jump a 3/16" gap & 22kv to jump ¼” in the open air, so that's why you need to use a spark plug. Or, a store bought plug checker. Remember, it’s 14psi outside of the engine & about 90psi at a 6:1 compression ratio in the cylinders & compressed air creates electrical resistance, so you really need the 17-22kv to fire the plugs when the engine is running.
50 Tips
Thanks Bruce, Old and R Geiger for your kindly responses. I was gone a day after posted and just got back in after messing w/the tractor befor posting back. #1 - its a 12V system. #2 - I started it up and it ran for rxactly 4 minutes before shutting down w/o a single sputter. #3- fuel flowing very nicely thru bottom of carb. I made sure the on/off valve before sediment bulb was exactly 2 turns open. #4 - pulled 2 different plugs separately to check for spark. NO spark period. I didn't bother to try direct battery to coil start - shouldhave I?
What befuudles me is why would it run for 4 minutes, shut down, no start, and then no spark??
Thanks again for any suggestion - ou are all great.
(quoted from post at 06:54:47 09/20/11) Thanks Bruce, Old and R Geiger for your kindly responses. I was gone a day after posted and just got back in after messing w/the tractor befor posting back. #1 - its a 12V system. #2 - I started it up and it ran for rxactly 4 minutes before shutting down w/o a single sputter. #3- fuel flowing very nicely thru bottom of carb. I made sure the on/off valve before sediment bulb was exactly 2 turns open. #4 - pulled 2 different plugs separately to check for spark. NO spark period. I didn't bother to try direct battery to coil start - shouldhave I?
I would suggest you reread Old's suggestion.
the why part is the ign switrch, resistor, coil, condensor will or can fail after they heat up. what happens is the resistance thru them increases to the point that that it reduces the current flow below the point that it takes to make a spark.
FInding no spark means you are that much closer to getting it running.
I would start by cleaning all the connections in the wire and parts that goes to the coil., switch, resistaor, coil, points and condensor. may be a rusty connection.
If the points and condensor have been installed for any lenght of time I would replace them. they probably need iet anyway. just use quality parts as from NAPA. the igh switch can be jumped around to see it it makes any difference.
good luck
" What befuudles me is why would it run for 4 minutes, shut down, no start, and then no spark??"
Did you jump the ignition switch like I told you?
If it's bad, it will get hot & fail.
