2n hyd pick up tube
need some help with my 2n noticed recently my three point would go up but wouldn't hold weight.
I found the pick up tube from the pump to the rockshaft piston has a split in it.
I can't find any available parts ,could fix it but would rather replace it if possible.
thanks for the reply, so did I understand you have them for purchase?
also what's the correct way to get that out of there it looks like I pull the pump down from the bottom first.
(quoted from post at 13:10:47 05/14/19) thanks for the reply, so did I understand you have them for purchase?
The pipe is nothing more than 1/2" steel hydraulic tube that is expanded roughly .005 at the top end. It is installed from the top of the case where the hole in the case is slightly over size. The bottom hole in the case is slightly under size. That allows for the pipe to be is dropped in from the top until top and bottom sections of the pipe both come up against the holes in the case. It is then driven the rest of the way (a scant inch) in with a suitable drift.
The old pipe can be removed by driving it out from the bottom or threading the top with a tap and using a bolt and puller arrangement. If teh center section has been damaged and weakened it may require a combination of both.
I don't have one on the shelf and would have to make a replacement - take me a day or two to get to it. You can email or call me for details or more info:
[email protected]
301.655.0631
TOH
