2N hydraulics
drmaxdc
I have a 2N that I just put a new safety valve in. Now, with a brush hog attached, it won't lift it. It raises it a few inches then starts bouncing up and down. It was cleaned out and new 90 w mineral oil put in. What should I do?
(quoted from post at 12:59:37 03/18/22) I have a 2N that I just put a new safety valve in. Now, with a brush hog attached, it won't lift it. It raises it a few inches then starts bouncing up and down. It was cleaned out and new 90 w mineral oil put in. What should I do?
Why did you replace the relief/safety valve?
Was it working correctly before you replaced the valve? Lifting the same implement correctly?
heck valve portion installed correctly?
when running. is there a newer version of the valves?quote="old"](reply to post at 20:20:31 03/18/22) [/quote]
