2N plug wires
Tom N MS
Any other suggestions on how to crimp plug wire ends on the wires? None of theseso called parts stores around here know what I"m talking about-don"t know their butt from a pop gun.Trying to do it with pliers and such just don"t get it-wires don"t snap and lock into the dist. cap like they should.
where in ms are you? Im in collins I have all the tools to install plug wire ends on all sizes of plug wires evan right angle ones
e-back or call me 601-765-8720 after 09:00
Ronnie, Thanks. I"m in Wesson-My Dad (who needs the tool) is in Bogue Chitto...Will call you later today..Thanks again..Gary
Yes, that is basically what it is but the crimper hole in the nose of the tool is just larger than those made for small wire ends.
got an old 'f' connector crimper?
otherwise.. stick wire thru.. solder, and then leave ends belled a bit for positive lock into the cap, and US for the plug head
it's what i use for the ends that goes on the plug itself, those that hav ethe clamshell grip for the wire and conductor. seems to work great for me. My tool does 3 sizes.. and usually the middle size works best.
(quoted from post at 01:39:43 09/25/13) where in ms are you? Im in collins I have all the tools to install plug wire ends on all sizes of plug wires evan right angle ones
Ronnie, know anyone around Seminary that bales hay?
Whopist
