2N temporary gas tank set up
stryped
I am needing to set up a temporary gas tank. I have a plastic lawn mower tank and some 3/8 fuel hose. What size/type fitting do I need to attach? the fuel hose at the carb? Something I can get at local hardware store.
I appreciate any help!
I would recommend installing a shut-off valve if there is not one already on the tank.
I use the steel fuel line and force a short rubber hose over the flare to connect the lawn mower tank to the steel line.
my set up. A lined paint can with a hold in the lid. Attached a shut off valve to the can then fuel line to the carb. Works great....Actually the 550 cord I'm using to trying to the cleaner lets it wiggle a little but not bad
