2N transmission oil
quiggs12
Do I get just a straight SAE 90 oil or is there something else that I can use??? I live in Maine so it does get cold and I know I am suppose to use 80 if it is below freezing. Thanks
You can use UTF "Universal Tractor Fluid" for the cold weather. It will be more "leaky" in summer, and, if the lift hydraulics are at all weak, they will perform worse with the thinner oil.
You can use the New Holland Spec 134-d hydraulic oil - it is the equivilent of 20w. Know though, that this lighter oil will find its way past old seals and gaskets much eaiser and will cause leaks and usually oily brakes.
Dan
