2N Wiring Harness
sbaugh1964
This is my first posting so if I'm doing something wrong or posting in the wrong place I'd appreciate feedback on how to do this in the future. I have a new 2N wiring harness (2N14401) but the wires are not labeled. I've included a photo of the harness and would appreciate a list of what each wire is supposed to be connected to (starting on the left side and ending on the right). Thanks
Thanks Bruce. I have 2N wiring diagrams and fortunately on the tractor there is no protective casing so it's easy to follow along. My understanding of the harness in the photo (going left to right) is this. The yellow wire with back electrical tape connects to the resistor. The red wire goes from the resistor to the distributor. The left yellow wire connects to the resistor and the short yellow wire (middle group of wires) is the other end and connects to the top terminal of cutoff. The black wire goes from the bottom terminal of the cutoff and connects to the generator, the long yellow wire with the large eyelet connects to the solenoid where the negative battery lead is connected. If this is correct, then I need to add a short piece of 12 gauge wire the yellow wire that goes from the resistor to the cutoff so I can run it through the ammeter.
(quoted from post at 11:21:44 04/30/15) Google "wiring diagrams JMOR"
They are pictographs; very easy to follow.
75 Tips
just a thought , before i hook up the wire connectors i slip a length of heat shrink over it about 1 1/2 " log , hook up the connector where it go and slide the heat shrink over the connector and heat it to shrink around the connection to help keep moister out and it makes you look like a pro installer !
have fun,
rick
bought it at home depot , dont kmow if yt carries it.
