3-53 update
greg oliver
I struggled on and flay be rolling on. Had fuel lines switched on the pump. Engine looks like it was in a roller had similar but different pump setup on the back. Has a guillotine in the supercharger. Had to make new engine mounts the old engine had a mount that went around crank pulley and the rear mounts were part of rear bell housing. Governor had an electric motor for control but I couldn?t use it due to clearance issues. Don?t know any history on the engine but starts good so far and runs fine. This is a Tampo roller I had to change oil pan and pickup tube as well as new O rings and fire rings on the head. Just a visual check of the head for cracks between valves. We are a low budget operation but will have to buy a newer roller sooner or later.
