Many thanks for the advice on the injectors. I finally got over to the
tractor today and they came out easy. I took out 2 out of 3 so i
didn't have to re time the rack, i read that somewhere.
Anyway, i have them taken apart, it was an ordeal as they were pretty
solid, but i won.
I have a manual for 71 series, and it kinda goes through taking them
apart, putting them back together seems too straightforward.
I see where i have to line up the gear in the injector to the rack
(the dots) Is this the only thing i have to worry about?
I am figuring out the injector operation as i go, fairly simple.
Will the rack move back and forth only when the injector is depressed?
The spray nozzle is clogged, without buying the DD part, what is a
common thing used to ream out the nozzles?
If there are any other pieces of advice in putting them back together
i would sure appreciate it.
I am getting closer to starting it up, just have to replace the fuel
line, it is rotted out.
Chris.
solid, but i won.
Chris.
