3 bottom plow advice
SHALER
For a 3 bottom mounted plow - 1st bottom or nearest the tractor plows a little deeper than I would like. The middle bottom plows at about the correct depth. The last bottom does not plow as deep as the middle bottom. What adjustment is needed?
Could be also shorting the adjustment on the right side lift to the 3 point arm to tilt the plow a bit to left. I would try that first.
#1, look and see if the plow's HEEL ( or rear wheel) is leaving a mark on the furrow bottom..if not, lengthen the 3rd link..
If it is leaving a mark , shorten the Rt link to level the plow..
One turn can make a big difference..
