First of all, thanks for the ideas last time. Talked to the power company. They'll upgrade me to a 3 phase service for free. They will provide my power to a 200 amp fusible disconnect, from there it is my responsibility.
My plan is to install a 200 amp outdoor 3 phase load center at the drop location, and use a 200 amp 3 phase sub feed lug, to feed the shop via a 200 amp 3 phase panel inside the shop. In the outdoor load center I will also feed the house via a 200 amp single phase sub feed lug, to a 200 amp panel in the house. Both of the interior panels will have main breakers for convenience. I understand they will both be sub panels, and need to run a separate ground wire to them as well.
Now the questions. Can the outside panel be just a main lug panel, since the fuse disconnect provides over current protection, or does it need a main breaker? Where would I bond? Also, using proper sized conductors are the 200 amp sub feed lugs acceptable, or would I need 200 amp branch breakers in the outdoor panel?
Honestly right now, it's kind of overkill with 200 amp setups in both structures, but this way I can always have the power company upgrade my service, and I will only have to swap out the outdoor panel, should I expand.
Thanks again, for working through this with me.
David
David
