3 point hitch parts
8e3k0
Where can one find the pins that are used when extending the lower arms of the 3 point for the late model 2 cylinder tractors? The pins are long with a spring over them plus they have a washer and snap ring at the the top. Pull the pin up to extend the lower arm right or left. Sorry I do not have access to the part numbers where I am located now till the end of the month. Need at least two of these. Any help would be greatly appreciated.
Thanks Ellis
Sorry I didn't find it for the 2 cylinder arms ,but Pin/ Pull Arm # F2693R and associated hardware for later JD applications can be found here " https://www.external_link.com/f2693r-pin-pull-arm-1 "
Thanks for all the help, will be in Yuma Arizona in the new year and I will order a set.
Thanks again.
