3 point hydraulics
Suitsme
When I start the tractor the 3 point hitch immediately raises to the upper limit even with the raise/lower lever in the lower position.
Nothing can be done to lower the 3 point and this is with a rotary mower attached.
I am guessing a faulty valve somewhere.
Ideas?
I best explain, this is a JD 4010 diesel tractor
Suits welcome to YT! In case you can’t figure out how
to get there see the link. Depending on what view you
are in the jump to or hop to drop down box below
each post will also get you there. I know a few things
about that era of JDs but the 3 point is not part of that
knowledge. Best of luck!
YT John Deere topic section
Welcome to YT
Have you tried change position oh L/D lever under seat? For optimum rotary cutter operation ever should be in position "D". It's the 3 pt control cable or linkage has seized from dirt/rust & valve control arm isn't moving when handle on dash is moved.
(reply to post at 05:30:47 10/25/20)
I will check that out. Not sure what is meant by L/D lever but the "arm" that the raise/lower cable attaches to doesn't seem to move.
I will have to wait a few days to look at it as it is 10 degrees today
