Hi guys,
I recall reading a recent post about the location of the pins in the under-axle bracket that anchors the stabilzer bars that control side to side sway of implements on 9N's. After reading this info I realized my pivot pins were not aligned with the lower lift arm pins. I moved the pivot pins into the holes that are in alignment vertically as well as fore and aft with the lift arms. Now I can attach both ends of either the left or the right stabiler bar. But when I go to connect the second bar (the other side)it is a good 1-1.5 inches short of alignment. The top link is OK, and either side will connect but not the second side.Its almost as if the bars are too short or the brackets are wrong.I've adjusted the R-side lift arm to several lengths but none allow connection.I'm sure I'm not the first to run into this. Ideas??
