3 point manure scoop
does anyone out there remember a ford 3point scoop that had tines on it and mounted the rear of a ford 8n. The hog farmer i worked for years ago had one mounted on a 8n. It sure wasn't up to the class of a skid steer, but it was alots better than a pitch fork for sure.It had a canilever type system on it, and would go up and over the sides of the old type spreaders. I have an 8n and would like to have one to fix up. Any info or a picture of one would brighten my day, and bring back the good old days. Thankyou and have a wonderful day.
Stardard Dearborn 3 point manure loader, lots out there. On the 8N the pin that the rocker for the top link fastened to went thru ears on the diffenterial housing and that is where the top fastened to, on tractors without those ears like the 9N,2N there was a model loader that instead of fastening to the diffy housing fastened to the bolts that hold the fenders on, also on those as the diffey was not drilled underneeth a different lower mounting that also held the booster cylinders was used instead of the 8N swinging drawbar mount. And there were chains that none the lift in the bend and adjusting them different controled max lift height.
Here it is. Found it under tractor photos by looking for FORD REAR MOUNT LOADER. Also in Google Images
