3 simple Kuhn tedder questions.
AJinPa
I am finally buying a tedder. It's a Kuhn 2 star trail type. Like new. Picking it up Wednesday. 1) What is the reason the bar picks up on the one side? It looks like it puts a lock pin into the one rotor. 2) Can it be towed home behind my pick up? It's 10 miles. All back roads so speed isn't a factor. It looks like the tines might drag. 3)When it gets home, I'd like to pull it with my Super C. It should scoot right along in the field with it right? Thanks guys for any help.
1) to narrow the machine for the road, if you look the rotor will also have a tine with a hand screw that pivots in. The lock for the rotors is so the folded time stays put.
2) angle the hitch so the tines are level front and back, go slow.
3) Super C will play with two rotor tedder.
You'll love the tedder, we've had an 2 rotor 3 point Kuhn since the 80's. Really speeds up haying.
The pull type can literally run on any PTO tractor, they only take 15 PTO HP or so and don't need hydraulics.
I do prefer 3pt for transport, but pull type only requires steering the in the field, versus steering AND lifting 3pt on turns for the mounted one.
I got the exact tedder, not sure how long I have had it now. Been a great tedder, what everyone else told you holds true. Only problem I have has is one of the thumb screws kept backing out so I just put bolts on it. Not had it on the road since it got home.
