3 Terminal automotive switch
Winehead
Took the 3 post automotive switch off while disassembling my 8N to paint, and made the mistake of not labelling posts. Is there a way to tell which post is ACC, OFF, BATT? I think one is labelled "BATT" but the other two are not. Not sure how I knew this the first time I put it on now that I think about it...
Well, there's NO "OFF" TERMINAL!
If "BATT" is labeled, there will be "IGN", which only has power when the switch is in the "RUN" postion, and "ACCY", which will have power in BOTH the "ACCY and "RUN" positions. EASY to check out with a test light.
Or, does the switch have a spring-loaded "START" position, making the third terminal "START"?
What are you working on that has a 3 terminal ignition switch ? If its an older tractor , use a 2 wire switch & the push button safety starter button . If someone has installed a 3 wire switch to eliminate the safety starter button , that's a NO No . Someone will get hurt or killed someday when starting it without first being sure its in neutral . Think safety please . God bless, Ken
Ken, it's a regular 3 post automotive switch that is part of a 12V conversion, as has been recommended on this forum many times. It still uses the push button to start.
Wine
Oh, sorry . I'm not much for converting to 12v . I like to stay as original as possible . I guess I get that from my Dad .His theory was if it can't or won't start as it was originally set up to do , well then find out why . Alot of times people convert to 12v to hide problems instead of finding the problems & fixing them . I do how ever like using an 8v battery on my 6v tractors . The only thing you have to change is the VR setting so it puts about 9.6v back into the battery . I've been running my 640 for about 8 yrs now with an 8v battery . In that 8 yrs I've only had to replace the battery after 5+ yrs & 1 headlite .So I'm well pleased . Good luck & God bless, Ken
