30 series gauge clusters
Helmsman
Can a stewart-warner gauge cluster from a gas tractor be used on a diesel that has the autolite cluster? Parts book shows them having different part numbers, but it's not much help beyond that.
Autolite's were used in the '30 Series only, so the S-W would need to come from a '30 series also, or a 700 800 or 900. The oil
Pressure gauge would be the only difference between the gas & diesel at that point. 60psi & 80psi were used in the diesels, 30psi &
60psi were used in the gas. Joe DeMaio repairs and restores both those clusters. 856-839-0578. If you have 2 models in mind, get back
for more specifics.
Ok, so the oil pressure ranges are different between gas and diesel then. I have a potential donor tractor with a good gauge, just wasn't sure if it would work. Thanks John
