firhead
I have a few older small engines (Kholer, Briggs) that call for 30 wt oil. Local auto parts guy says it's getting harder to find (everything
is multi-visc), though he had some. He says to go 10-30 or even 20-50. I know these old engines are loose, but I'm skeptical. What are you
guys running in these older engines? I'm in Colorado at 6300 feet - cold winters, hot summers.
Thanks,
Cliff
Every time I change the oil on something I turn the empty container over into a funnel and drain every last drop into a gallon jug. 5-30, 10-30, 10-40, 15-40, 20-50. Some synthetic, some not. That's what goes into my small engines.
Where I work we still have 30wt. in Briggs and Stratton, Kohler and Kawasaki brands. $11-ish a quart. And the small engine oil still has the zinc in it.
If you have to, you can go to 10w40 or 20w50. I wouldn't go to 10w30 or thinner unless I was blowing snow. The thinner viscosity oils will be consumed more quickly as the engine runs.
If mfg calls for 30 wt above freezing they get this
Mystik
JT-8 SAE30 Super Heavy Duty Diesel Oil
Blains Farm and Fleet # 025219 Mfr # 663006002004
Was $109.99
You Save $15.00 (14% Off)
Sale
$94.99
I have 100 gallons of Kendall 20w/50. That's what goes in all my old tractors and small engines and has for years. Also use it for chain lube in my chain saws.
Everything on the place gets 15w-40. It rarly gets below 20f but 100f+ is common. If it were colder I'd go to 10w-30 in Winter. I've run multi-vis oil for the passed 50 years.
The largest part of small equipment engines for the past 25 years has called for 10W30. A10w30 is a cleaner oil due to not having the extra additives to make it a 40 weight at operating temperatures.
10W30.. What does that mean??
It means it flows like a 10 weight when cold and like a 30 weight at operating temperature.
When I was a teen you had 2 choices at my local suburban Texaco....Havoline 20 or 30. Anyway, the owner had a
barrel where he would punch the adapter in the top of a can, install the can of oil in a customer's car, pull the adapter
out and set the empty can upside down on the rack to drain into the barrel. Have no idea as to what he did with the
oil.
I use to buy Kohler 30 weight at Local lawn garden vendor. They stock the Kohler 10w30 now . I got the Kawasaki 30 weight last time for our mower cause it was the 30 wt they stocked now.
