I had my 300 about 3 weeks and really wanted to take it on the Platte co tractor cruise yesterday. The tach cable was busted. I got a new one from John Saeli and put it in and it worked--I thought. I did 3 20 mile shake-down runs with the tractor to make sure it was ready for the cruise. I didn't want to be THAT GUY whose tractor craps out.
On those runs I noticed the tach worked but the hour meter did not. Seemed weird that one half would work and the other not, but another 300 owner said his was the same way. We were about 1 hr out on the cruise when my tractor started to make a whining noise. THe last time that happened on another Case the water pump was seizing up. The noise quit for a minute. Then came back. This time I noticed the tach needle was buried. The noise quit and the needle returned to operation. That's weird, I thought. The noise returned and the needle was jumping all over the place. I put my hand on the dash over the tach and I could feel it vibrating through the glass. I figured I probably should stop and disconnect the cable as the tach was seizing. But if the tach seizes, I don't need the cable (and I didn't want to be THAT GUY) so I continued on. Again the noise quit and the tach started working again and the noise did not come back.
After about 15 minutes on the road, I realized the hour meter had started to work. The tach and hour meter worked the rest of the 40 mile trip. That is truely weird, to this uneducated tractor owner anyway.
