300 heavy FH points?
I believe the 300 is the first to have the heavier points. I think below that it was the smaller version. Not going to swear on anything but that is my understanding.
You can shim small to large and you can cut down large to small(plasma cutter works best)
My Super C's have the small points and my 300 has the large. I had
a 240 with small points back in the day.
It's easy to use small point implements on a large point fast hitch
with spacers. This is practical for most implements. While my 300
would certainly pull my 2-14" C20 plow it would be hard to get the
wheels spaced correctly.
My 7' disc designed for the super c works great behind the 300, 2nd
pic. This is overkill because that disc works equally as well behind
the Super C. My blade designed for the SC works far better on the
300 due to the down pressure and a much heavier tractor.
1st picture shows my 300 pulling an 8' spring tooth cultivator
designed for my SC. I had to run a couple miles over to buddies
place and the road gear in the 300 was nice.
You could cut down large points to use on small point fast hitch but
I can't think of very many practical applications. I wouldn't cut
down my 3-14" plow or 8' disc harrow to work on my Super C.
My dad's 350 had large points. The 300 utility and the 450 both had large. Bought a rotary brush hog type mower and always had to use the spacer bars on it.
I have an 8ft fast hitch blade with wide points and my 300 handles it easy. I also have a fast hitch 2 bottom plow with the smaller points that hook up nicely to my super c fast hitch. I use the plowed shimmed for the 300 but would not consider altering the wide point blade, albeit would not be a big chore.
