300 non TA Help!
Where can I find the saft and bearing carrier used to replace with? My bearing cage is ruined from the bearing coming apart and splintered the shaft.All 300 I have found are ta tractors Iwas told 340+350 + 460 non ta tractors all use the same parts but no luck on them ! Thanks
other sources: possibly 666 686 656 and 504 544. They all seem to be listed using same TA unit in aftermarket catalogs. Non TA might be same.
karl f
I am getting the family 560 running again and it is a TA delete.
My brother had it, messed it up, let it sit outside for many years.
Engine is now overhauled and have pulled the top cover on the transmission to clean out the sludge.
I have to overhaul the PTO unit, weld in a different battery tray (pulled from a 460) install the gas tank and fire it up.
I will paint it this coming summer.
