300 Utility Engine Cylinder Rust
Ian_300U
I pulled the spark plugs from my 300 utility the other day and I found variying amount of rust and carbon build up. Is this something that I can fill the cylinders with something
like evaporust or should I pull the head? Whenever I try to get it ti turn over, all it does is click and the fan jumps a little, and then does nothing.
Squirt some Diesel fuel into the cylinders... take the starter out and bar the motor backwards until it stops turning again.... dont try to ram it through going forward , the pistons are already jammed and the fuel cant get down and lubricate where it needs to.
I typed most of my reply but when back and checked for replies before I posted. So seeing what Fritz wrote he has a good point but there is also a chance that the engine is stuck too tight to move at all. But for your sake I hope that you did see the fan move and what he is saying is correct. Here is my reply it may be a bit out of chronological order
..It should have been mentioned prior to this the starter should be checked for possible having the drive pinion locked into the flywheel. This is a common problem on IH products of that era. This can be checked by pulling the bolts that hold it on then pull it back, should be able to let you tell it is retracted. If while you are loosening the bolts you hear a click or this from inside the starter it is the drive retracting.
Did you see any liquid in the cylinders? The photos you shown all look dry to me. I would dump a 1/4 cup of automatic transmission fluid(ATF) in each cylinder. If you want to go the extra step you can do a mix of 50/50 ATF and acetone. Screw the spark plugs back in by a thread or so. If your tractor has rolling tires all properly inflated put it in 5th gear TA lever in the reward position if equipped and brake off. Rock the tractor back and forth by alternately pushing and pulling at the top of the tires. Do this several times a day or at least once. After a week you might get someone to help you on the other tire. Apply all the strength you can to rocking the tractor back a forth. You can try the starter again to see if it may be able to get it turning. If this does not work waiting another week doing a repeat would be a good idea if you have plenty of time and patience. The final attempt to get it to turn starter out and pry against the stater gear teeth on the flywheel. I am talking about really get after it with 2 foot of leverage like a crow bar.
Currently have a 56 vac14 w the same issue. I poured brake fluid into every cylinder, I put it in the road gear and rock it back and forth every time I go by it. I have about 1/8-1/4 wiggle on the fan blade when I do it so the motor isn't completely locked. It's a game of patience and working it loose slowly.
Also since you ask of you should pull the head, I'm wondering what you used to get such useful pictures of your cylinder bores?I'm assuming that whatever you used had to be small enough to go through the sparkplug hole meaning that it's small and flexible.
How long was this engine sitting. And if u inspected it and saw rust in the cylinders that is saying u need oil in them. Most any thin oil is good. Mystery oil, atf, hyd oil. Or kerosene . Even if u mix some diesel in it too. Diesel alone does not do much as it is a poor lube. Plus never keep rotating it forward with the starter!! Use a hand crank or rear Wheel to turn it back and forth a bit more each time till u make one revolution. Good idea to remove the starter to turn it backwards. Plus pull the valve cover and check the valves by tapping each one on the rocker to make sure none are stuck. Then adjust them also at the same time. But my guess is u dong have experience in that. Also when a person knows his tractor will be sitting for over a year its preventative maintenance to remove the plugs and squirt some oil in the cylinders and turn it over a turn or two. Then let it sleep.
I have no definite answer as to how long it was sitting, but there was a decent sized tree blocking it in the shed it was parked in from what I was told.
Thanks for all the advice, one thing is mine has a loader and I have no good way to get that off the ground to move it back and forth at all, the best I can do is maybe an inch or two before the bucket stops it. What kind of work would I be looking at to remove the starter?
Starter is 3 bolts and a couple of wires.
Take the bucket off. Not the whole loader, just the bucket. Three (or four) pins and it's off. If you're reasonably strong you can "walk" it out of the way one end at a time, or just drag it with your lawnmower, car, or whatever. You can jack the loader arms up and prop them up with blocks if they reach the ground after you remove the bucket. Now the tractor is mobile.
Those little cameras are useful - for the price they are a must have for anyone doing work on engines.
If it were mine - I's put about a abundant amount of Liquid Wrench in each cylinder (enough that you can see the liquid cover the top of the piston with a few millimeters of fluid) and forget about it for a week. Then take a look and see if it is still on top of the piston or if it worked its way past the rings. If it made it past the rings I'd put another cup of Liquid wrench mixed 50/50 with some ATF in each cylinder and start trying to get it to rock in 5th gear or use the crank start and apply a fair amount of torque. If it refuses to move wait another week and do the same. You will want to start with the penetrating oil because it is thin enough that it will soak in around the piston and soak the rings before eventually dripping into the crank case. ATF will take longer to do the same so thinning it with penetrating oil will help.
If you get it to break free the cylinder walls will be pitted and it will burn some oil - but you gotten a good look inside the cylinders - there really isn't much rust - compared to some that have had 10 years of seeping antifreeze rusting up everything. Most of the time I advocate pulling the head to see what you are dealing with - you know with your inspection camera. Yours looks like it should move with some work. The next thing you will deal with is a valve(s) that is seized open or just very sticky. Pull the valve cover off and start soaking it too.
Yours appears to be usable if you get it broke free - some are just so bad that even if they broke free they are still in dire need of an overhaul.
So most loaders have buckets that are secured with a pin on each of the piston rod ends. A few times I've seen bars run through them and then welded so you can't remove them but that's very uncommon for someone to do that. Once you remove the pins the bucket while still heavy can be rolled over at the very least. Another way would be tobe to take a highboy jack, and Jack the bucket up a bit, you will want to have the remote open for this and it will take a bit of trial and error to find out which remote and which direction to pull it. Once you have the bucket lifted you can either chain the bucket up off the ground or slip a block between the frame of the tractor and the loader lift arms. The hydraulic system may be stick as well due to sitting so be aware that the rams might not want to move at first. I'm attaching a photo of my 300u with the bucket off.
