sunsettractor
I've had this tractor for a few month's and have been trying to work the bugs out, it has quite a few. It has run very rich since it came to me, carb adjustments have helped , but only a little bit. Recently it flooded bad, gas was running out of the carb and it quit running altogether. Also, oil got contaminated with fuel, oil level on dipstick was an inch and a half over full mark. Removed carb and took apart, float was all beat up and full of gas. I soaked the carb for a couple days in parts dip, then again in CLR to bring the casting to like new appearance, purchased a rebuild kit and float from YT,the kit did not contain a new air mixture screw, just a load mixture screw, that screw was much shorter than the one that was in the carb and also too large to even fit through the carb, so I re used the old load screw. I used the clear hose in the carb bowl drain method to get the fuel level set to 9/16 below the bottom of the top carb casting, it stays at that level so I think the needle valve is sealing properly. With the load screw turned out four turns, and the air mixture screw out 1 or 2 turns, it starts right up, but the exhaust is thick black and the engine lopes at idle, upon opening the throttle, thick black smoke billows from the exhaust pipe and smells like raw gas. I lowered the fuel level in the carb bowl and made no difference, turning the air mixture to any position in or out makes no difference, with the load screw turned all the way in against the seat, it idles well and runs fairly smooth bot still puts out a black cloud of smoke when the throttle is opened up, but misses and runs erratic at full or close to full throttle. It is this way with the air cleaner hooked up or disconnected, so a plugged air cleaner is not the problem. Can anyone provide any suggestions as to what could be wrong here?? Other than go buy a different rebuilt carb I am kind of stuck....Thanks,Tom
