3000, 4000 power steering pump lines question
aircrue
In the process of restoring my 75 4000su, and upgrading the metal pump lines with hoses, (wish I had taken a pick of that) and cannot find any info as to which side of the column the supply and return lines connect to the power steering box. Is the return on the left or right of the box? Brother already scrapped the old lines, or I'd have figured it out that way.
Thanks! I appreciate it.
As of now I'm thinking the pump return line (rear center fitting)goes on the right side of the column, left to the pressure (lower front) side of the pump.
(quoted from post at 13:27:03 04/06/20) Thanks! I appreciate it.
That's what the parts drawing shows.
(quoted from post at 12:27:03 04/06/20) Thanks! I appreciate it.
Thats correct and how they're attached on my 400SU
Thanks! This helped me sort it out. Working great now!
For future reference:
Pump Lines:
Right Side Column- Return (back of pump)
Left Side Column- Supply (lower pump)
Steering lines:
Lower Column port- Inboard lines
Upper Column port- Outboard lines
