3000 Ford charging system
Dale Berman
Before I bothered you all, I searched the forum for a someone else with a similar situation and couldn"t find anything. I"ve got a 68 3000 diesel. My problem is somewhere in the charging system. It all started when I tried starting it on a cold day. I ended up draining the battery. It finally started when I jumped it off. The charging light went off after I gave it a little pepper like it normaly did. The next time I used it and from then on for the last year or so I"ve had to jump it off every time. It seemed like every time I jumped it off, it took more and more pepper to get the charging light to go off. It finally got to the point where no matter how high I reved the engine, the light never went off. I"m finally ready to fix this now that I have some time off work and don"t really know where to start. After I run the tractor for a while and shut it off, I guess what voltage is left in the battery is only enough to turn the charging light on. Not even a click from the starter. I pulled the generator off and took in to advanced auto. They couldn"t tell me how much it was putting out, just that it was putting out. I don"t have a voltage tester. Also on a different subject, I have seen a few different kinds of block warmers but don"t know which one to go with. Of course my tractor has a hex head shape block plug and happens to take the most expensive block heater known to man (or at least I haven"t found one for under $150). Does anyone have any suggestions on which block heater would be the best? I know the cheapest route would be one of those magnetic ones, or I could go with the kind that goes in the radiator hose. I"m open for many suggestions.
Thank you very much for your time,
Dale
(quoted from post at 09:56:51 11/24/09) Before I bothered you all, I searched the forum for a someone else with a similar situation and couldn"t find anything. I"ve got a 68 3000 diesel. My problem is somewhere in the charging system. It all started when I tried starting it on a cold day. I ended up draining the battery. It finally started when I jumped it off. The charging light went off after I gave it a little pepper like it normaly did. The next time I used it and from then on for the last year or so I"ve had to jump it off every time. It seemed like every time I jumped it off, it took more and more pepper to get the charging light to go off. It finally got to the point where no matter how high I reved the engine, the light never went off. I"m finally ready to fix this now that I have some time off work and don"t really know where to start. After I run the tractor for a while and shut it off, I guess what voltage is left in the battery is only enough to turn the charging light on. Not even a click from the starter. I pulled the generator off and took in to advanced auto. They couldn"t tell me how much it was putting out, just that it was putting out. I don"t have a voltage tester. Also on a different subject, I have seen a few different kinds of block warmers but don"t know which one to go with. Of course my tractor has a hex head shape block plug and happens to take the most expensive block heater known to man (or at least I haven"t found one for under $150). Does anyone have any suggestions on which block heater would be the best? I know the cheapest route would be one of those magnetic ones, or I could go with the kind that goes in the radiator hose. I"m open for many suggestions.
Dale
irst thing I would do, before getting involved with the charging system, is to make sure you have a good battery. Put it on a charger & use a one dollar hydrometer (Wally-World) to check the cells.
If you don't have a charger, take battery to auto supply for a free charge & test. If that all proves out, the next thing we will all want to know is whether it is factory original vs changed to different charging system (generator/alternator/regulator/internal/exterma/brand/any info available).
I never haad much luck with the magnetic heaters, I used either the lower radiator hose heater or the external block heater. Boh worked well for me.
Good lick and be careful.
steveormary
ditto what jmor said. sounds like #1, a bad battery, and #2, a geny that likely needs rebuilt.. probably throw in a regulator 'just because' lucas regs are junky anyway..
soundguy
Thanks for the replies. My system is factory original and hasn't had any changes to it. I will put it on a long term charge and see what I come up with. I'll need to pick up a hydrometer. What exactally does it measure and if the wer in the bat is low, do I just put some distilled water in there?
Thank you.
Dale
(quoted from post at 14:26:12 11/24/09) Thanks for the replies. My system is factory original and hasn't had any changes to it. I will put it on a long term charge and see what I come up with. I'll need to pick up a hydrometer. What exactally does it measure and if the wer in the bat is low, do I just put some distilled water in there?
Thank you.
Dale
istilled water. Measures specific gravity of the electrolyte, which relates to state of charge, as in full, partial, dead.
I was fighting the same problem with our 3000. It was the regulator. You can"t trouble shoot much without a voltage meter. You need at least 13 volts at the battery with it running(my new regulator puts out 15 volts)
(quoted from post at 12:09:04 11/25/09) I was fighting the same problem with our 3000. It was the regulator. You can"t trouble shoot much without a voltage meter. You need at least 13 volts at the battery with it running(my new regulator puts out 15 volts)
Ditto, same here.
I had thought the generator armature was dirty or was probably needing brushes, since I was having to rev up the RPM to get the light to go out. But when I had it checked out, the shop said the gen was fine.
Like yours, it was a bad voltage regulator.
Ronnie
