3000 injection pump question
JohnDeere83
New to the ford tractors. I have a little fuel coming out of this metal pipe at times. What exactly is this pipe for?
That’s the vent tube that also acts as a over flow
That style injection pump has its own oil sump and it’s oil should be changed every time the engine oil is changed
If you have fuel dripping out that tube you have fuel in the pumps oil sump, this can be caused by a bad diaphragm in the lift pump of internal leakage
I’d change the oil in the pump and if it drips fuel and or oil out that small tube again I’d replace the lift pump
Changing out the lift pump will drain most of the oil from the inj pumps sump, make sure to refill its sump before using the tractor
