My 300 had a broken tach cable when I got it. Finally got around to replacing it, but there doesn't appear to be anything in the distributor housing to plug the square cable end into. I assume there should be a drive gear??
I haven't found a diagram that shows the internals. The ones I see show a block off plate on the hole for non-tachometer models.
Anybody have a diagram, picture or description of what part might be missing here? The threaded part that the cable screws onto is still on the dist housing, but it just seems to be hollow with nothing inside for the cable.
thanks
thanks
