301 valve timeing
Not familiar with that model, but I would think there would be one on the crank gear to match up with.
First you said the CAM gear has two sets of marks, now you say the CRANK gear has two sets of marks. Which is it, or BOTH?
without knowing anything about your dilemma as it applies to that particular engine, I would guess that the cam gear has one type of mark to time it to the crank and another set of marks to time to the distributor drive. examining the mating gears should make it clear which is which.
the way i see it, the marks on the cam gear are essentially the same, and since the cam turns half as fast as the crank, use either one of the double dots, and the use the double dots on the crank gear, If the cam had a [two sets] of single dots, then u would use the single dot on the cranks gear, or did i miss something, but i never worked on a 301 either !!
just the crank gear sorry for confusion the crank gear has a single dot and 2 dot and the cam gear has two single dot when I line the two single dot witch are male too female when you match teeth cam seems out of time when I set it too the two dots on crank and one of the single dots on cam they don't line up good seem like they can go one tooth ether way but the cam seems more in time just want to make sure it is write
Turn the crank to where #1 would be on TDC. look at the cam lobes on #1 & they will be down. See which marks are close & install there.
OK... I'm gonna GUESS the crank gear is the same as a diesel (D282, for example) would use, and the extra set of marks are to match up with the injection pump drive idler on the RH side of the engine. (Conventional RH side.)
So if you are FACING the front of the engine, the unused set of marks will be at the LH side, and the correct marks for the cam drive will be to your right. Like THIS:
<img src = "http://i167.photobucket.com/albums/u125/27Grainfield/IH/301_zps81f8e731.jpg">
Make sense?
Follow Teddy's directions and you can't go wrong. There are two sets of marks on the crankshaft gear because on a diesel engine you have to time the idler gear. On a gas engine you do not. The single dot on crank gear aligns with single dot on cam gear. The double dot on crank gear would be the marks you align with idler gear on a diesel engine.
