craigco
What are the differences between engine block casting r26160r and casting r32020r. Both are 4 cylinder one is 3010 the other 3020 I belive. Can they be swapped? Lost an engine in my 3010 crack through the o ring lands for the liner.
I believe that all 3010 diesels lacked an oil cooler while all 3020 diesels had an oil cooler.
The 32020 block would come with the entire front half of the tractor. I don't remember if it had an oil cooler on it or not. When did they go to pencil injectors? This has the big ones still.
The big injectors were used for the 1964 model year in the 3020. The switchover happened for the 1965 model year along with making differential lock available.
