3010 diesel injector stuck.
I am looking for tips or advice on removing a stuck injector on my 1961 3010. Injectors 2,3 and 4 came out easily with just a small amount of pressure from a large screwdriver. Number one injector is stuck fast. I have been soaking it with PB blaster everyday for over a month and still it resists every amount of pressure. I built a fork shaped tool that fits around the injector hopping to pry it out but that was also a fail. Any ideas are welcome.
Have someone put pressure with a small prybar while you hit the injector with an air hammer with a blunt tip. I found that the vibration from the air hammer will usually break them free. At this point, the injector is probably bent any how..
Thank you fellas for the advice. I did try giving the injector a twist last night and I did get the injector to move back and forth about 15 degrees. I was also able to lift it out if the bore about 1/8 of an inch, Just enough to see where the top and bottom of the injector thread together. I will try the pry bar and air hammer next. I agree, it is probably bent at this point.
