If the idiot light is staying on it sounds like she's not charging. NOTE its the Generator NOT the VR that needs Polarized.
NOTE when you had the genny tested it may have got Polarized at the opposite Polarity that your tractor is!!!!!!!!!! If it was and you started the tractor without first correctly re polarizing the genny (so it matched tractor) YOU COULD DAMAGE THE VR. Some VR's are labeled for POS ground others NEG and some can work at either polarity, hope your tractor and VR and genny are all correct, matched and the genny is polarized.................
Place a voltmeter on the battery and when shes sitting there not running a good charged battery ought to read around 12.6 volts,,,,,,Then start her and run at fast RPM and if coupled to a good charging system battery voltage should rise to at least 13 to the 14 volt range IF IT DONT RAISE, AGAIN, SHES NOT CHARGING.
Use a small jumper wire and when shes running temporarily wire the Gennys FLD post to a good frame ground IF SHE CHARGES THEN (says genny itself is okay) BUT NOT OTHERWISE the VR is bad or not well grounded. BOTH the Genny and VR need good frame grounds to work, use a jumper to insure both are well grounded n see what happens???????????
If you put one lead of a meter on frame ground and the other on the Gennys ARM post when shes running at fast RPM, if the genny and VR are working the voltage there should be near the same as if the non grounded lead were placed instead over on the BAT terminal (which wires to Battery) since the Cutout relay should have latched in closed. If it measures around 12 volts on the BAT terminal (battery voltage) but way different over on the ARM (Gennys output) terminal, the genny isnt working.
If you just use a test lamp (NOT running) with one lead to frame ground, the non grounded lead ought to light up (if battery has at least decent voltage) on the VR's BAT terminal, but no light on the ARM since the genny isnt spinning. Then when running it again should lite on the BAT terminal and if genny and VR are good also lite up if placed instead over on the ARM terminal.
If when running with one test lamp lead on the BAT terminal and if the genny and VR are good and charging the other lead on the ARM terminal SHOULD NOT LIGHT because the cutout relay is closed,,,,,,,,,If it does light, the genny is not producing and the (NOT to BAT) lead is getting a frame ground via the genny brushes... i.e. NOT CHARGING.
So I dont have to reinvent the wheel each time this question gets asked (at least once a week somewhere) I have a URL Link to my Troubleshooting Procedure below, work through it step by step and it can help diagnose the problem. Note if you dont have an ammeter simply ignore the parts about it but the rest is basically the same
LET ME KNOW WHAT YOU FIND,,,,,, insure BOTH genny and VR have good frame grounds,,,,,,,,to be safe re polarize the genny before start up
John T
John Ts Troubleshooting
