3010 load sensing shaft and retainers
JD4440
I lost load sensing shaft retainer and shaft slid out losing oil. Before I could replace retainer I was mowing hay and shaft slid out. Special retainer bolts still in place. What do I need to do to keep retainer in place. Maybe a strap bolted to the wishbone to keep retainer in?
Side to Side play in the "wish-bone". It needs to be shimmed so the caps stay in there as when the wish-bone is pushed from one side to the other side it pushes the caps off. And yes, Deere sells a shim kit for that.
New bolts and retainers. Do not use a lock washer on the bolt so the bolt goes into the retainer farther. As others said, shim the wishbone.
