Olliejunkie
As I previously posted my pump quit. Timing marks on my flywheel say 14, 10, then there is a line, and then says tdc. When my pump lines match up it's a little after tdc. I took my pump out and had it repaired and reinstalled it at the same place as it has been running there for since I got it 15 plus years ago. The pump does have advance on it so should be at tdc. It did start up very easy after I installed it and runs as good as ever. I did try to back the timing up after I got it running but is pretty hard to flex the lines that much. What would I gain by backing it up? Not sure if it's worth it as it starts good and has enough power for what I use it for.
Also the problem with the pump was the plungers were varnished up and stuck. I'm not sure what caused that as I believe it only sat a couple months. Fuel wasn't over a year old. I use to always put power service treatment in it but switched to standyne treatment last year.
