Ed Douglas
Morning Forum…. I had an issue with my 3010 starting sometimes I would have to turn the ignition switch off and onto two or three times before it would engage…. The dash lights would come on and dim while the ignition switch was turned to the start position… finally the other day it stopped starting altogether when I turned the ignition key on and jumped. The two posts on the starter solenoid, started right up and ran…. So obviously the ignition Circuit is working…. So now I’m a bit bit confused, is it the solenoid acting up or is the ignition switch the culprit?…. Any thoughts from the electrical gurus?
