3010 transmission
dawley
Hello maybe a shot in the dark: I am putting a crown and pinion in a 3010 and at the point of putting the transmission back together with a newer countershaft, reverse pinion gear, and 1st and 3rd gear on the pinion shaft. My problem is when I go though the shifting sequenses I have no reverse at all. I was very careful to get everything back as per the book,obviously I goofed. I would like to have some idea what to target before I start ripping it apart again. As far as the gears, they all seam to mesh and the shifting seams proper. If anyone has any thoughts I would greatly appreciate some advice.
Thankyou
sounds like something in linkage and it’s not fully engaging in reverse
Reverse only shifts on top shaft where the synchro drum shifter sits at.
