3010s key switch wiring
jdman2009
Does anyone have a wiring diagram for the key switch for one of these. I bought it not running they’d tried replacing the switch and cut wire ends off. There’s one that has two wires I think they may have put it with the wrong wire.I’ve seen all the pictures of how to hook it up but that doesn’t help with the wiring. Problem is I have electric shut off and I don’t have power to the pump when cranking. I’ve got it with key on but loose when cranking the engine. I seen some of aftermarket switches say they won’t work with electric kill so I ordered the right switch from NH.
I've had to put two switches in mine, one time bought it at tractor supply, next one online. These switches were used back to Ford thousand series. I'll look for a diagram
