With the potential quality of parts nowadays there's NO reason to replace ANY ignition parts on your tractor if it is starting and running well.
The chances of getting a coil or condenser of at least equivalent quality to what you have now are not good.
In other words, if it ain't broke don't "fix" it!
That being said, I bought a gas 4020 some years ago and the points looked well used, and the distributor cap was weathered so I bought NOS Delco points, condenser and distributor cap and rotor on ebay and set them aside 'til it would act up or I felt like taking the time to install them. Also, a set of spark plugs.
After 10 or 12 years, by last year, it was still running VERY well but the cap was looking so crappy (externally) I finally installed the new one and the new points, keeping the new condenser on the shelf in case it's ever needed. The new spark plugs are still "on the shelf", as well.
It's a GREAT idea to check the dwell, timing and spark advance, though.
When I got the tractor, the spark advance wasn't working so I disassembled the distributor and cleaned it up and lubed it. Thankfully, nothing there was significantly worn.
I still have a working dwell meter, so I could accurately set the (used) points when I got the tractor, and a timing light to check the advance and set the timing.
Someone mentioned EI, that's well and good, but (rarely) they DO fail unexpectedly, leaving you "dead in the water" unless you remember where you put the old points and associated parts, while you wait for a replacement EI.
