3020 Buying advice
NWOK
I have the opportunity to buy a late 3020 diesel Powershift with side console. It s not perfect, front axle has been broken and repaired, hood is a wreck and will need replaced. The tach shows 5500 hours and may be original. Has new injector pump and dealer has just gone through the transmission. I haven t seen it with my own eyes yet, just pics.
2 questions:
It appears that the Powershift lever guide has more wear than I have seen on others, should this be a concern?
What s it worth?
With that much wear it was probably a loader
tractor which could explain the hood and front axle
never figured out how to break the front axle but
some people can screw up a crow bar in a snow
bank
The tractor has a weight rack on it, it could have been a loader tractor at some point or they put the weights back on it. I can t tell if some of that wear is paint over a peeling decal or just wear. I ve not seen any pictures of other tractors with this much wear even some with 10000 hours. Would you be hesitant to buy at the right price?
If they went through the transmission and the rest is
ok I?d buy it they are good little tractors . I have a 66
diesel powershift .
Late model power shift 3020 s are hard to find but a very handy tractor. I have had several power shift tractors and IMHO that tractor has a lot more than 5550 hours just by looking at the wear that you mentioned. The injection pump being rebuilt$6/$800 or new plus power shift being gone thru would cost a minimum of $5000/7k+.More pictures would help but if motor is good it would be worth around $10K at top end but finding a hood wont be cheap and if front end isn't very good replacement is almost cheaper than buying replacement parts depending where it is broke.I once bought a rough estate 71 4020 syngro that just had $16K in receipts from JD for an FFA tractor restoration for $8K.That being said the 3020s 270ci motor are probably the hardest replacement to find as there were few applications.Tires also can make easily $1K+ difference.
I agree with the others that with shift guide worn such as it is & engine has been overhauled that the tractor has a lot more than 5000 hrs of use.
The meter on my '67 4020 powershift doesn't work, but I'm sure it has more than 5500 hours. There is zero wear on the console at that point from the shift lever. The decal that shows the gears does curl up at that point, although the photo doesn't show the decal, unless somebody painted over it. You would think the shift lever would be shiny at that point also.
That dash shows more than 5500 hours. I have seen some worn that bad mostly loader tractors. In the 3020 I am not a fan of the power shift as they seem underpowered due to horsepower loss from powershift. I do own three early 3020 diesels syncros that we farm with and a gas utility. It still would make a nice chore tractor. Tom
Here is the working tach. It looks to be the correct type to be original. I know it?s always hard to tell for sure. I?ve looked at other 3020?s with 10000 hours confirmed and the shift guide did not look like this at all. That?s what makes me unsure, is it more of an illusion with the photo and the paint over the decal or real wear from loader work.
(quoted from post at 09:22:40 01/03/20) That dash shows more than 5500 hours. I have seen some worn that bad mostly loader tractors. In the 3020 I am not a fan of the power shift as they seem underpowered due to horsepower loss from powershift. I do own three early 3020 diesels syncros that we farm with and a gas utility. It still would make a nice chore tractor. Tom
Not planning to farm with it. Just a chore tractor for mowing, grain auger work, moving hay etc. We just don t have anything this small right now to do that kind of work.
(quoted from post at 01:24:01 01/03/20) Late model power shift 3020 s are hard to find but a very handy tractor. I have had several power shift tractors and IMHO that tractor has a lot more than 5550 hours just by looking at the wear that you mentioned. The injection pump being rebuilt$6/$800 or new plus power shift being gone thru would cost a minimum of $5000/7k+.More pictures would help but if motor is good it would be worth around $10K at top end but finding a hood wont be cheap and if front end isn't very good replacement is almost cheaper than buying replacement parts depending where it is broke.I once bought a rough estate 71 4020 syngro that just had $16K in receipts from JD for an FFA tractor restoration for $8K.That being said the 3020s 270ci motor are probably the hardest replacement to find as there were few applications.Tires also can make easily $1K+ difference.
Let me be clear on "transmission gone through" the guy told me he had them "check it over and replace any clutches that needed replaced" I don t know how much he spent on it, but I don t think it was $5k.
Yes, I wasn t born yesterday. I think I assumed that it was unlikely that one of these tachs would last that long without failing, judging by the number of them you see that have been replaced.
Here are the other pics I have. Hard to tell much since it s been painted. Just wanting to get a sense of what it s worth and it s it s one to go after or let it go.
I don?t know why you?d be afraid to buy that one
you?ll never buy a new 65 horsepower tractor that?s
built like that one Is . I wouldn?t have anything but a
powershift in that tractor mines ballasted to 9700
pounds and I use it for heavy tillage and planting
and spraying and everything else that needs done
Fun little fact I learned recently about those tachs is they will often have a year printed somewhere on the backside. I replaced one in a 4000 which had a tach that was replaced sometime in the 80's (I couldn't make out the second number). Made sense because the owner said JD put a new engine in it at that time. The new one I put in had a year on it also.
Dupont overhaul
Smashed hood
Shift guide wear
Broken front end
Front pump drip line routed improperly
Pto shield missing
SCV and 3 point lever knobs missing
Mis matched tires
All point to me like a tractor that was used hard and had minimal or poorly done maintenance.
Do you know that the hour meter actually works?? Tach needle could be working without recording hours.
I wouldn't go more than 3K on it, even though it is a side console. That way if something big goes boom, I could at least recover most of it by parting it out.
YMMV. Good luck.
The pictures were a big help.The tires look excellent plus you have 8 wheel weights that will bring $100+ each you also have some front weights that will bring $75 each. I cant imagine someone going to the work to paint without doing something to the hood as it can be made to look and fit a lot better.I would question hours but it does match the other gauges.If it runs good with no blowby and trans shifts as it should it is not as bad as I expected.The third link is better to have than PTO shield.I guess what the least the seller will take and what you are willing to give.Just by fixing hood putting on knobs would have added more dollars than a below average paint job.Good luck
NWOK check PTO to make sure it starts and stops like it should.You didn't picture wide front .Hard to tell from picture but the seat framework can be a good indicator of wear.I see tires 1 looks new other mismatched. if a dealer has it He certainly could have presented it better.It not nice but might work fine.The outer gives some clues but the things that cost money to fix are internal.
I keep finding things as I see it has a RollGard cant tell if canopy is there .But a nice RollGard will bring $600+ and with canopy $1200 if nice .By the fading of gauges I doubt if canopy has been on since new.
The signs are there that it could it have been used on a cattle feedlot or dairy farm in a previous life, maybe several owners ago. A replacement wide front end could cost around $1000. With the rough condition, extensive repairs and fresh paint I feel it could easily have 15,000 or even 25,000 hours. Fresh paint can hide a lot of sins.
Driving it will tell the story if it will work for you. Check the archives for how to check out if a PowerShift is OK. Check the antifreeze for rust and the hydraulic fluid for water. Take a good look at the drawbar for wear, and if the seat rocks side-to-side and slopes forward. If you can buy it for $5,000 you will have some cushion to make more repairs. With the fresh paint, I suspect the dealer wants over $7,000 and IMHO you should keep looking.
test drive it by applying the brakes in
every gear after its warmed up engine
above 1500 rpm if none of the gears slip
and make sure PTO shuts off
I think the late model and PS is what got me initially interested. This condition in a synchro would be an easy pass. Probably good advice as signs pointing to hard life. There was a late 3020 PS that seemed pretty rough to me sold for $13900 on AuctionTime recently. These seem to have way more value than expected.
Gee I thought I did good on mine I guess I didn?t
realize how bad of a deal an improperly routed
pump case drain line was sounds like they should
have paid me to take the hunk of junk. I change
engine oil and all filters every 200 hours or less
grease every day but oh well I guess that?s my
poor maintenance showing again
I would agree that if it were a syngro this post would not be on here.No one knowa number of 69/72 3030/4020 P.S.but they are considered a somewhat low production tractor and usually bring a 2500/3000 premium.
The best indicators should be the drawbar wear or the brake and clutch pedals for sure , they do not lie about usage
(quoted from post at 01:47:56 01/04/20) Gee I thought I did good on mine I guess I didn?t
have paid me to take the hunk of junk. <img src="https://www.yesterdaystractors.com/cvphotos/cvphoto1260.png">
You are missing the point. To have the drain line just hanging there points to someone that didn't take the extra minute to tuck it into the frame rail properly. How many other things were only done to 80% of correct by Bubba over the years? That tractor was obviously rode hard and put up wet, and then covered with paint. I have a console 4020 here that I have posted about. Came off a cattle ranch as a loader tractor. My drain line was outside the frame too. It was on the cowboy Bubba maintenance program for a long time. I knew what I was getting into and was close to being paid to take it. 3 years later I have nearly 1/2 of it's value into it just in parts with me doing the free labor. I fix old stuff, and you fix old stuff. I enjoy it. I think you do too. I was merely listing things that point to a poor maintenance program on that tractor, which all weighs in on actual value. Topics like this are always a pain in the a$$ because we never hear what the asking price is. But we are all asked to be expert appraisers by looking at a few pictures.
SV, please understand I am not trying to pick a fight here. I understand everyone will look at that tractor through a different set of eyes and have a different analysis of condition and value. And I assume your comments were intended with some sarcasm. :D
Dealer[jockey] at Nazareth Tx. Feed & Supply, asking price in 9000 range, I'm sure tractor has closer to 10,000 hr. than 5000; [ tach drive cables brake, tach rpm needle can work ,but not count hrs. ] likely traded off cotton plantation, If I were closer I think I'd take chance on it, as Larry stated the extras roll-guard, front weights, 8 rear weights, 2 remotes,[no engine disconnect/ must be a southern bell/ Ha Ha] & it being a mid to late "71" PS. Diesel; with tranny , & injection work done, tires good; makes it worth it...
Painting a hood in such a bad shape is crazy. If I had to 'fix it' fast, I would have slammed a 3010 or early 3020 hood that is easy to find for $150 and put a round muffler (let's say so the tractor sounds better). :)
