3020 carb load mixture adjustment
MikeDean
3020 with a Marvel Schebler carburetor, the load mixture adjusting screw stays ?loose? after adjusting. So loose that it?ll turn itself out while running. The o ring has been replaced. Any ideas?
Its in the correct position on the carb and when adjusted it runs well. But when it runs the screw vibrates out. Never tightens.
A lot of mixture screws have coil springs over them to prevent this, can you put one on this one. Where I used to work we would wrap threads with teflon tape to prevent vibration from turning them, but don't let any tape get into the carb!
