3020 Diesel surges
Had the injector pump rebuilt and is has run good. It has gone to surging just off idle until middle speed. Is there an adjustment on the pump to control this?
Is the diaphragm lift pump working?
Does it act the same if the fuel tank is full vs. nearly empty?
One other thing to check is your foot throttle working correctly I’ve seen them in all sorts of states of repair causing a couple things from sticking to wot to no response especially if it’s not used often
Even had one where customer had removed pedal and the linkage still causes trouble
