I have a John Deere 3020 diesel with a
PowerShift transmission. I recently added
a front loader to it as I hope to move and
feed round bales with it. Just used the
tractor a few days ago to cut some hay
with a haybine and have recently used the
loader boom to move some other equipment
around the farm. I am now having some
hydraulic issues.
First started the tractor to prepare to
tug a round baler, and could barely even
get the tractor out of the shed. Started
fine, seemed to idle fine. Put the tractor
in gear and just sat at first. Returned to
park position, and tried the gear again.
As I let off the clutch pedal tractor
didn't move, then started moving very
slowly and hesitantly before the gear
finally caught. I also have now steering
at all, left or right. My 3 point will
raise when the tractor first starts with a
bad vibration, goes back down very slowly,
and will not come back up. The brake
pedals also jump back up, nearly throwing
my foot off them when I try to depress
them. Front end loader will not operate at
all either. Reverse gears performed same
as forward gears.
Also, while using the front end loader a
few days ago, when I engaged the lever to
allow the remotes to operate the hoses
running to the front loader were
vibrating,jittering, and rattling around
really bad. Loader boom would go up
intermittently and very slow, but came
down really fast, and seemed to bounce as
it came down. I've previously added
hydraulic oil, and the level is where it
needs to be on the dip stick.
Prior to all this, the steering wheel
would max out all the way when turning to
the right, but the tires would slowly
catch up, and the PTO would not stop
turning even in the lock position.
Any help would be greatly appreciated.
I've looked over the John Deere forum
here, and other areas as well, have yet to
find the posts relating to these issues. I
have the manuals for my 3020, operator's,
technical service, and parts catalog, but
need some fresh ideas what to look at.
hydraulic issues.
as forward gears.
