3020 Remote Valve
I'd appreciate some advice please. The leak on our JD 3020 remote valve has almost become a “flow” so it’s time to fix. I’ve checked out prices to replace; nearly $600 - $1,000!!! Is there a kit available with some instructions (I am not a mechanic, so keep it simple, please!) Is there somewhere to send the unit to have it rebuilt economically?
Thank you! Bob
Is this an "early" one thats mounts under the hood ?
Or is it a "late" 1969 and newer that mounts at the rear of the tractor?
Would it be possible to describe the part or the joint where the oil is leaking from ? Some leaks are shadetree mechanic fixable, some are not.
It is a newer one that mounts at the rear of the tractor. I have already removed the "box" from the tractor. The leak appears to be from the rear of the box. Are there valves, seals, that can be replaced rather than replacing the entire "box"? Thank you for your help! Bob
Yes they are re-buildable, and it's not unusual to see one leaking , they are not one of Deere's finner ideas, there is an upper kit,RE 10924,$21.25 and a lower kit ,AR82570.$41.75 , If your leak was where the hose plugs in you need the lower kit ,this is the most used one,It, seems like I re-seal 4 or 5 a week, if you have the upper kit installed I would recamend putting 4 new poppet valves, AR86535,$48.50 each.If yor not familuar with this kind of stuff,you shouldn't try it your self, thats why I do 4 or 5 a week:)
Again, thanks for your help. The “box” only has two bolts. When up side down, they are centered at either end of the box. The leak appeared to be coming from the rear of the box, where the “cylinders” (?) push in and out, when the valve is open or closed (?). Depending on what is connected (mower/conditioner, log splitter) they also leaked from the front to varying degrees. If I open the “box” will I find parts that can be replaced? Thanks!
Does it look like this ?:
The AR82570 coupler kit will come with all the packings, o-rings and back-up rings needed to reseal this assembly. A Deere dealer will probably want about $75 labor to install the kit. An independent shop will want around $50.
To fix it yourself, you will need patience, an o-ring pick, small needle-nose pliers, a way to clean the parts, and a clean, well lit, work area.
Pull the snap rings 24 and the springs 23. This holds the levers 39 in the coupler. Pull the levers down out of the assembly. If the front of the couplers haven't been mushroomed from hammering, they should slide out the back with a little effort. The balls 12 will be free to fall out so be ready. I would leave parts 15, 16, 17, 18, 19, 20, and 21 together and not try to take them apart unless you are certain they are leaking here. The usual leak points are 10 and 11, 13 and 14, 25, and 31 and 32.
Any metal parts that are damaged will not come in this kit. Pay close attention to the direction the white back-up rings are "spiraled" together , and that they are installed on the correct side of the o-rings as shown.
