I have a late 3020 that I will be rebuilding the starting system on. I will be replacing the 2 6volt batteries with 2 group 31 truck batteries an fabricating new battery boxes to fit new batteries, installing all new 4/0 battery cables from ground to starter, the starter will also be replaced as was damaged trying to start too many times with the weak batteries. So my question is should I get the gear reduction starter or stay with the standard starter with the added cranking amps of the larger batteries, cca on the group 31 would be at 950, would the gear reduction be any benefit in this situation? thanks in advance for any input.
