Hi everyone, I have a 3020 diesel, never had a starting problem until a couple days ago. I ran the tractor for several hours a couple days ago with no problems. Parked it overnight and got a few inches of snow overnight. I plugged in the block heater and the battery tenders for a couple hours the next morning. Went to start it and I heard what sounded like a short (sizzling noise) then nothing. No click from the solenoid or anything. I pulled the dash panels and disconnected the push button wires. I couldn't find any evidence of burned wires. The previous owner had installed a key switch - he ran a hot wire from the battery to the switch, then from the switch to the starter solenoid. I removed the key switch and hooked the wires back up to the original pushbutton switch last fall. Never had any problems. I'm getting 24 volts from the battery to the switch, but when I connect the switch wires, I'm only getting 6 volts at the solenoid terminal. Any ideas what is going on? Is there another relay somewhere that I am overlooking? Any help would be greatly appreciated!
