gomi_otaku
I was assessing my steering free play this weekend. My right steering "arm" is mounted so it is really close to the tire, while the left side has more clearance.
I noted that rocking my steering back and forth, the arm moves before the tire- like there is a certain amount of slop.
I unbolted the arm and saw how it it splines, and has a couple of "shims" between the arm and the tube.
No matter how that is tightened, it has some play there. Do I need to replace the arm, or the shaft inside the steering tube, or both? Good way to assess it? Or is it not really a problem? I know I have a little play in that tie rod end as well.
I thought it was odd that I couldn't line up the splines to move that arm farther from the tire without it being REALLY far away. If that's clear without pics...
