Well, adjusting the clutch pedal play and tightened the pedal adjustment bolt too tight and broke off the end piece. I ordered a new clutch shaft arm lever and in the meantime I am trying to epoxy the end back on to get by....or I am considering drilling 1 or 2 small bolt holes through the pedal. lever to hold it in place for now. It doesn't seem like it would take much (like a couple 1/4" bolts) but I don't want to mess up and break the clutch pedal. Thoughts?
Part B is bigger-I hope I don't have to split the tractor to put the new shaft arm it. Is it a bear to get the lever off the shaft and can I get to the cotter pin on the inside through the clutch port hole underneath? Thanks as always
