3020 with hyd broken coupling
Coupling and crankshaft pulley broke . I was thinking maybe the front pump caused it . Should i be able to turn pump by hand ?
Anyway to test test ? Hate put all back together and than find pump bad
Also little A frame holding pump is cracked on one side .
Maybe the frame cracked and help sanp the pulley ?
And i want to change to cooling hyd system to the newer one . Whiich has sep tank and is plumbed is series but i need diagram to plumb it and cant seen to find one ??
Does 4439 front pump fit 3020 ?
My guess is broken pump bracket causes pump drive coupler & damper to break. One should be able to turn pump by hand. 3020 & 4430 should interchange
